Best Tires to Run on a XF?
I put on the Michelin Super Sports on both my XF's just recently.
One had the Continentals, and before they hit the wear bars and after only 4 years, one of the treads completely separated from the sidewalls. Googling it, I found others with the same issue with Continental, so never again with those tires.
The other had the Hankooks that the dealers around here recommend. I hated those tires in the way they handled.
The Michelins are only $225 at Discount Tire, and they are top notch.
NuJagLuvr (07-28-2015)
YMMV
NuJagLuvr (07-30-2015)
The newest Continental ContiPro Contact, updated from the one fitted to older cars, is a superb tire in its class. Anecdotal evidence of one tire failure is not relevant to your decision. The factory Contis on my '09 were all good down to the wear bars.
Competing tires in that category include the MXV4, the Pirelli P7 and the Michelin Primacy all season.
Michelin super sports are from a much higher performance category and are noisier and harder riding as a result. Continental and Pirelli both make competing tires in that category.
Check out the high performance all season tires if you want to step up a category. Supersports are overkill on an XF. Michelin makes the awesome Pilot A/S 3, Conti the DWS just updated and superior to the former class leader and Pirelli s new P Zero All Season is a top performer also.
You should add what you want to do with the car and what is important in a tire for YOU to get the best recommendations. Otherwise it's like going to a party and asking everyone which sedan you should buy. Lots of opinions but a lower chance it will ultimately be what you want.
Yet more bad info from jagular. Do the googles, it wasn't one tire failure.
And my Michelins ride smoother and quieter than the Conti's ever did.
You are again pretending to talk from authority when you haven't even tried them on the XF.
I hate Continental of ANY kind..the 03 X I had, wore them and they rode like ****!!!
My XF now also has Continentals and they are also crap....I can't wait till they wear enough to justify a new set of Michelins..one of the rear set is so screwed up, I can only drive with them on the rear, as it pulls the steering to the left otherwise..So now I can't even rotate them ever....Anecdotally speaking that is
Anecdotally speaking you appear to be in a very small minority of tire users.
Continental Europe (which supplies Jaguar ) consistently gets good reviews. For example:
http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
Now the American tire maker General tires also builds Continental branded tires for the American market. Perhaps some of the issues arise from General tire manufacture although more likely it is driver abuse if the failures are reported by American consumers.
I have fitted a variety of Michelin tires to cars I have owned. Michelin makes tires that ride harder and make more noise than many competing tires, especially from Pirelli. Generally, though not always, you also get higher dry grip and handling in return for more noise and a harder ride. Michelin also makes quieter tires if you want that quality in your tire. Hard to get both qualities from a Michelin tire in my experience.
Comparing tires sold for one category to tires from another category is essentially meaningless.
It has also been my experience that people in general know the square root of fa about their tires and what makes a good tire, anecdotally speaking.
You're welcome to your opinions but stay away from incorrect facts eh?
You are I believe a minority of one if you find Michelins to ride "smoother" by which I assume you mean more smoothly, whatever that means, and more quietly than Continentals.
Assuming you've had your hearing checked recently have you found anyone else who experiences the same difference? Tire Rack maybe?
Has anyone run a 245 on the front of their XFR? Who ever owned the car before me put 245s on the front instead of the 255 the rears are factory size 285/30/20.
When it comes time to replace them I will be going back to the factory size but I thought it was odd they used a narrower tire.
Advantages would be less rolling resistance?
If the stagger is too much you'll find the wider tire will grip more and earlier but reach the breakaway limit sooner making the car twitchy. One assumes the sidewall height is the same and the profile higher for the 245 which will run at higher slip angles so tend to increase understeer. However, as you apply more power in the corner or increase corner speed the lower profile but wider rear tires may let go earlier than the fronts.
I understand there is no substance or facts in anything you say...But as always, you seem to flatter yourself when no one else cares...eh?
245 section is fitted to non R XF models. They will run slightly less rolling resistance but it would not be a good idea to fit too much stagger. Although stagger is mainly for cosmetic effect it does change the handling balance. Wider tires do not generate more grip they just develop grip earlier in the cornering process. They actually develop less grip for braking or accelerating.
Go to Tire Rack and look up what tires you have. Then look at the recommend wheel width for the tires. You want to run in the middle of the range which will usually be 1" to 1.5".
Too wide a tire on a rim makes the contact patch narrower because the edges get rounded due to the gap between the beads is smaller. If rim is too wide the tire gets too stretched across the tread and it doesn't make as much contact in middle.
But to answer your question, a 245 should be just fine on an 8.5" rim. Just looked up a Bridgestone Potenza S-04 245/40/20 and it's recommended rim is 8-9.5". Theoretically, the 8.5" rim is on the small side for a 255.
I had the terrible factory continentals when I bought my car. Horrible vibrations. Balanced and rebalanced every couple thousand miles while the dealer tried to correct the vibration issue. After 15,000 miles one was beyond being able to be balanced. I put BF Goodrich's on and I couldn't be happier. No issues 10,000 miles later.
