BG 44K
Funny enough, Land Rover recommends using BG 44K to clean injectors which may be causing misfires.
Have a look at the attached memo SSM46917.pdf
Have a look at the attached memo Attachment 202564
Re: this post and your other surging post - did we not just go over this a couple of weeks ago???
https://www.jaguarforums.com/forum/x...e-5-0l-188124/
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
I'm about to change the fuel filter in my 09 XF SC, before I do that I heard that BG 44K is good to clean the injector and what not, and I have 115k miles. Is it recommended to use, and if so should I use the fuel cleaner before the fuel filter change or after? Thanks
As much as I love this forum and respect and appreciate the members that help contributing to have a more fun experience with Jags, there are still those members that ruin everything for the rest because of their ignorance and lack of knowledge.
I have been chasing a problem in my car that has been there for about a month and a half (Resolved btw). I literally changed everything that could cause a surging idle from plugs, maf senesors, coils, ..... etc etc and if you are wondering why I didn't just read a code to figure out what's causing it simply because there were no codes, just the damn surging idle so I had to choose the troubleshooting approach.
Anyways, BG products (at least to my knowledge), solved my problem with surging idle. I literally been reading on here "don't use them, avoid them, you are wasting your money bla bla bla",, when you actually ask any of those people who tell you to avoid it they (most of them) never actually used it themselves.
Theoretically speaking, this BG product is not supposed to hurt your engine nor any other parts related to your engine or fuel system or anything. So if you hear someone claiming misfires or any other trouble it is because just ignore them,, there has to be something else wrong with their car either they know about it and butt hurt that BG didn't fix it or don't know it is even there.
If you are looking to use BG 44k I recommend going to a certified shop by BG and do the air induction cleaning service as well, it is also a different bottle than the 44k usually it will say GDI cleaner or air induction cleaning service. I thought about it this way "If it won't benefit my car it won't hurt it" and indeed it did benefit. It cleaned the intake valves. YES it did not clean the intake the valves as thoroughly as if I had taken the intake manifold out and used a brush and cleaning solvents but hey it did 90% of the job for 10% of the cost. So do whatever makes you sleep at night.
Same story happened with K&N drop in filters where a lot said that it caused them trouble, Hey I used it and picked up 13 whp (with a tune) on the dyno (mind you my old filters were dirty). Again don't let people's ignorance or lack of knowledge change what you feel like is right.
Last but not least as I mentioned before I am not affiliated with BG company in any way nor am I trying to advertise for them. I am someone who tried their product and was very satisfied.
Best of Luck
Sam
![Icon Jammin](https://www.jaguarforums.com/forum/images/smilies/icon_jammin.gif)
Listen up Kentucky Cowboy,,,![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Best of Luck
Sam![Icon Jammin](https://www.jaguarforums.com/forum/images/smilies/icon_jammin.gif)
Best of Luck
Sam
Received 2,263 Likes
What croco did was a different product injected into the intake.
Apples and oranges.
croco (09-09-2017)
everybody is happy and have had a lot of problems go away plus it can't harm anything so might as well give it a try. My only other question is should I add it after changing the fuel filter or before?
What I would do personally is run it before you change the fuel filter. If the problem is corrected then you don't need to change your fuel filter, take it back to the parts shop and get your money back.
However, if nothing changes you have a part in hand and you can swap it out. That way you have eliminated one possible part that could cause the problem you have (If you have one).
The BG 44k is supposed to clean fuel system starting from the tank till it is out in the exhaust. Are you suspecting your Fuel filter to be faulty?
Received 3,239 Likes
The 5.0 XF SC has a "for life" fuel filter, it's integrated into the fuel pump which sits in the fuel tank, and the the only way to change it is to change the whole fuel pump which is expensive both for the parts and the labour.
Put another way the fuel filter does not need to be changed unless there is for some weird reason a major problem with it.
Sorry about the mix-up, in UK and Oz the 09 XF supercharged was the 5.0 XFR and the 08 was the 4.2 SV8.
yeah no worries, it's not hard at all it's located in the wheel well of the front driver side. Shouldn't take more than 20 minutes, thanks anyways
Received 6,332 Likes
