BMS Calibration
Has anyone purchased and changed their own battery in car. I have read that the dealer should do it account of the BMS (battery monitoring system) requires calibration. Apparently it is connected to the negative terminal. what happens if you change the battery yourself does the BMS not work?
nasa25 (02-28-2016)
Their aint no such thing....but as you have mentioned on other threads on the forum....you have been told to change it...so just go ahead and do it! Reset your handbrake...and I hope you have not bought a battery in vain while you had another fault that was giving you a starting problem arfter fueling up!!!!
I find this forum very helpful. All the best to you all
Drive safely Johnny jag
trosty
26
12-18-2022 06:40 PM
tbird6
01-10-2010 02:49 PM
