Bonnet hinges
For some reason, the pedestrian protection airbags have deployed which seperate the bonnet hinge bolt.
looks like 2 airbags and bonnet hinges required although some on this forum have repaired the bolt.
If there is a fault with the pedestrian system that has not been fixed I would not plug in the replacement air bags as they may go off.
Received 3,259 Likes
Without checking I am fairly sure the PPS (Pedestrian Protection System) and what/how to replace are fully explained in it.
thistle4celtic1 (01-14-2023)
Here is a thread with similar problems. Look at Ben's entries. He is fighting EXACTLY what your going thru so a private message to him might save you a lot of trouble researching this?
Underhood Airbags Deployed
I think he is still in the process of the repair but has done a good bit of research and work to his car already.
As posted above this forum has little to no information as the US did not get that system.
