Boot unlocking problem
Are you serious?
All these issues points to another issue of securing the vehicle (auto lock)
The button not working is also related to the questions I asked.
Anyways, this forum has helped plenty, and plenty. I dont know why you would contribute to pushing off my concern to another page when this can clearly cover it.
XF2LIFE (08-10-2023)
Received 2,259 Likes
Are you serious?
There's harness links to the boot button, that is also connected to the electronic latch. Any of these wires can trick the on board system to throw those messages off, but then again the title for this post is Boot Unlocking problems, not necessarily just for dead button.
did you manage to find a cure for it or a fuse? Thanks
hi what I done on mine was change the locking latch. I got one on eBay which was labeled genuine, it’s been a while now and it still works and it’s so easy and straight forward to fit
Tagrep (07-11-2020)
#28
The boot catch is electronic. If you can open the boot at all then the electronic latch is working. The problem with the boot lid switch may be broken wiring at the boot hinge rather than the boot lid switch itself. Does the metal emergency key open the boot lid when you turn it in the mechanical lock concealed by that rubber blanking plug?
