Bought the luggage compartment side net accessory, now how to install - RESOLVED
I bought the Jaguar luggage compartment side net accessory from a Jaguar dealer (under $30) but it came with no instructions. It looks like I might need to peel back the interior trunk liner and poke some holes through which the plastic clips go. It seems like a useful thing to have (and frankly should be standard) to keep small objects from rolling around in the trunk.
Has anyone installed this or know where I can get some instructions?
Thanks.
Here's a picture from a dealer web site.
Thanks.
Last edited by GGG; 09-08-2012 at 06:31 PM. Reason: Add 'RESOLVED' to thread title
Long Islander,
I've bought and installed one. It basically involved poking a hole with and awl the expanding it with a drill bit. Note to be carefull when poking the initial hole to avoid wiring. I felt up under the carpet to where I was planning to poke the holes to feel for anything to avoid. Also I did not use a drill with the drill bit. I turned it by hand to avoid hitting anything. The metal frame had to be flexed outward to engage the side of the luggage compartment panel as shown in the picture. Otherwise it would not reach across the opening as shown. I used a flat board under the carpet while putting the holes for the bottom attachments to avoid scratching the paint.
Hopefully this helps
BB2
BB2
Thank you, that is helpful. I have what I believe is called a rotary hasp, which is shaped like a cone and can be used to file holes to make them larger. It is attached to a drill. I think I'll use that at a very low drill speed.
Jaguar could have made this much easier. For example, the plastic clips could have had threaded backs that you push through the hole that you make with the awl and then fasten using plastic thumb-turn nuts on the backside.
Just out of curiosity, do the 2012 models come with this net as standard equipment?
I could see if they added it in later models and then offered it as an accessory to those who bought the car before they designed the luggage net.
https://www.jaguarforums.com/forum/x...ide-net-80398/
X_Type_South_Africa
12-09-2015 05:37 PM
swarm27
08-29-2015 07:37 AM
2009, cars, compartment, compartments, install, installation, jaguar, luggage, net, nets, side, trunk, uk, xf
