Brake fluid flush- anything special?
I did a search to see if there is anything unique to the XF for brake fluid flush. I came across something that mentioned something about the electronic pump and some unique things that had to be done. Is there anything different with flushing the XF? Can I just flush as normal?
Received 3,216 Likes
Just after you do your flush that way, you want to drive the car and hard ABS stop it a few times to move new brake fluid into the ABS actuator. Brake fluid in the ABS actuator dose not move until the ABS is used, or the dealer or ABS service equipped shop remotely commands the ABS to cycle. While moisture causes corrosion in the rest of the brake system, it can cause that and brake fluid crystallization in your ABS.
We all should be cycling our ABS at least 1x a month anyways.
![Icon Bowrofl](https://www.jaguarforums.com/forum/images/smilies/icon_bowrofl.gif)
I believe there is a misunderstanding of the brake fluid system...
Whether you bleed the brakes via the old fashioned two man method or the pressurized method the dealer uses..The ENTIRE brake fluid system gets expelled and replaced as the new fluid is added..Including the ABS circuit..No amount of old fluid is left behind..It all goes through it as well...Braking your car to activate the ABS system unnecessarily, is putting needless stress on the brakes/system and leads to more pad/rotor wear than you need..
When I got my rotors, pads and fluid replaced a few weeks ago the shop simply gravity bled the old fluid out then filled up with new fluid. Same thing when I had the rotors skimmed and new pads and fluid a year ago. Both times I bedded the new pads in with a dozen or so strong braking efforts (hard braking down from 50 mph to 10 mph, repeat), but not hard enough to invoke the ABS. No braking problems since either time, and the ABS works as it should (although I've invoked it only twice due to some muppet pulling out on me from a side street).
Thanks!
Bleeding and Flushing are two different processes. ABS solenoids are NOT cleared of old fluid in a brake bleed or flush WITHOUT ABS activation. http://www.stoptech.com/technical-su...-brake-systems
Cycling the ABS was common on older systems, not so sure it's required much these days. I also checked the TOPIX and replacing the ABS modulator/controller doesn't require a special bleeding procedure - just your usual pedal pump so I doubt the Jag system has any "hidden passages".
DPK (03-24-2016)
Did you see the age of that article - 2001?
So you do you with Topix.
and I'll do me with my hands on and Topix/Manual.
smokphattys
12-18-2010 07:13 PM
rothwell
12-17-2009 08:09 AM
