brake low warning turned off on its own?
On my '13 XFR, I had a brake low indicator warning a few days ago at a little over 13,000 miles. However, after turning the car off and turning back on, the indicator disappeared.
As I understand it, once the sensor wire is worn through, there is no way for the indicator to be "cleared" unless you replace the sensor or bridge the contacts.
With that in mind, is it reasonable to say that my brakes are probably still fine, and that it was a temporary electronic fault?
Received 3,220 Likes
Gotcha... yeah was planning to do that this weekend, but the brake warning light just came on again, and from looking at the rear pads at an angle through the wheel spokes, they do look pretty thin.
Received 2,192 Likes
Mr. Brutal:
I would normally take your word as gospel, BUT when my sensor got cut, i eliminated it in the circuit by shorting the two wires going to it to shut off the light. With the sensor hanging in air, the light was still on. So, I agree that it is a grounding circuit, but I believe the ground connected and then is disconnected when the circuit is cut. It does not make sense, but that seems to be the way it is!
Mr. Brutal:
sparkenzap (10-09-2015)
