Which brake pads
Which brake pads
Hi What brake pad do I need for my 2008 xf 2.7 as I have just been told by the mot station they will need to replaced soon. Is there a brand I should look for? and what can I expect to pay for a front set. And should I get the backs done at the same time.
Thanks in advance for you help
karamayoko (10-13-2022)
Just replaced my pads and discs with Ferodo and they are excellent and I expect OEM.
I bought them from here: https://brakeparts.co.uk/shop/Jaguar...%20and%20Drums
I put EBC Red Stuff brakes on my car about two months ago and I like them. They aren't 100% brake dust free, but they what little dust does accumulate can be quickly and easily wiped away. As far as performance, they are noticeably better than the metallic pads that were on the car before I replaced them, and also the metallic ones left about three pounds of dust on the wheels if I even looked at the brake pedal once.
I will say that during the break-in period they were a little squeaky, but that soon disappeared. However, as it's been getting colder here the squeaks have returned, but I attribute that to the simple fact that ceramic pads just need to be warmed a little work optimally.
Overall, for the price I think they were a good choice.
Did you do the final pad bed in process that EBC recommend for red stuff? After I think it's 300 or so urban miles (or more on the highway) you need to do a series of 60mph to about 20mph hard braking stops. That is supposed to do the final bed in and help avoid squealing
In addition some lube on the back of the pad where it touches the piston can help
Powerstop Evolution Plus Pads - No noise - No dust - Initial bite not as pronounced as OEM semi metallic but they stop just fine and i'm still amazed at how low dust these are compared to the OEM's - Wish I made the switch years ago - would have save a lot of time cleaning wheels - and they seem to be easy on the rotors - Rotors still look new - no lip after ~15k miles. Still plenty of pad life left too .
Received 3,274 Likes
I put them on my old XFS (355 mm front and 326 mm rear) and they were great!
Problem is they don't make them for the 380 mm front or 376 mm rear brakes.
Never used them myself but lots of XF owners on this forum are very happy with R1 Concepts rotors. They do plain, slotted, drilled or both (I think!).
harryf (12-16-2017)
If your Akebono's aren't producing dust, they aren't wearing the rotors.
I have always had greatly reduced wear on steel rotors from true ceramic pads like Akebono and Powerstop compared to OEM semi-metallic pads. And that makes sense. What you said doesn't make sense.
The main contribution to dust on the wheels is the rotor being worn off. That is why Porsche as stated in the new issue of Car & Driver is putting on a coating for the steel rotors to prevent the dust.
I know this is old, but for future readers, I think you mean pads. The pads are what makes dust. I mean the rotors do wear a smidge, but all that dust is black not silver lmao.
hmaster1
10-03-2016 11:26 AM
JimC64
03-02-2015 08:07 PM
