Brake pads low..?
Received 3,226 Likes
That said, you don't know which sensor triggered (front or rear), and it's possible that one or more of the unsensored pads is worn a lot more. There are two sensors, LHS front and RHS rear, and both on the inner pad, so that's only two out of eight pads being monitored.
So I recommend you whip the wheels off and have a look, it's not that hard.
The outer pads are fairly easy to check, you can poke your head inside the wheel well and look at them side-on, but the inner pads are a little harder to see with taking the calipers off, you need to make like a snake under the car with a good torch and maybe a mirror.
