Brake sensor
Received 3,274 Likes
PS - there are only two sensors, one on the LHS front and one on the RHS rear.
When it wears through it breaks the circuit (which triggers the message/warning), so once it has activated it is useless and needs replacing.
But new ones are cheap and easy to replace.
I ran into that over a decade ago with a pre-owned Lexus, only the 50 cent part retailed for over $150 at the parts counter. The solution posted on a Lexus forum worked a treat. I put a film of solder over the broken contact and sealed it with epoxy.
