Breather pipe part number?
Hi all,
There's a thin plastic air pipe that runs from a T piece towards the back centre of the engine to both inlets.
Could someone tell me the part number of the pipe on the left (oil filler side)?
This is a thin pipe about 5mm diameter, covered in a mesh sleeve.
It's so brittle, mine's broken. I've got an air leak somewhere, causing Restricted Performance errors, I'm trying to track it down.
2010 year 3.0 D S.
A
2010 year 3.0 D S.
A
Received 3,226 Likes
You can download a copy of the 3.0D Workshop Manual from my Dropbox here: https://www.dropbox.com/s/lghw4v21pw...op3LD.pdf?dl=0
I've had a quick look through my copy of the Manual and I can't quite figure out what part you are talking about but you may have better luck than me.
Then if you can figure out what it is called in Jagspeak the best place to look for the part is Britcar, see here: Land Rover Parts and Jaguar Spares | Britcar UK Ltd. They consistently have the cheapest prices I can find for JLR parts.
alinton (11-06-2017)
