Broken Plastic Tubing Under Engine Cover - Help Identifying
My check engine light came on and a scan showed something about the secondary air valve. I took the engine cover off to poke around and soon spotted these broken plastic tubes that are supposed to go into the intake manifold. What are they and what is their function? Could this be related to my check engine light? (I can't imagine it's not)
Ron,
While fitting the new part I would also try to figure out why the old one broke like it did, and maybe take some preventative measures.
Maybe it was chaffing or burning on something?
I know on my 5.0 SC there is a thin rubber tube which runs from the air induction piping to the S/C cover, and it sits right on top of the alloy cooling system crossover pipe, which gets extremely hot. The first time I looked at it I noticed definite wear/burn marks where it touched the crossover pipe, so I taped that spot up.
Same thing with the TCP intake, except the new rubber tube is longer and touches in two places now, so I have taped both of those spots.
For future reference for anyone with the same issue:
I picked up the part I originally specified at the dealer yesterday and it was actually NOT that part. The part I specified was separate from the part that broke on my car. The actual part I needed (and, fortunately, the dealer had in stock) was part number AJ88894, shown here: http://www.jiparts.expressweb.jp/con...8_aj88894.jpeg
Ron,
philwarner
05-04-2020 10:01 AM
maywho
02-14-2016 11:30 AM
