Bulge in dash board - 2010 XF Premium
#41
thePest007 (02-09-2017)
#42
Thanks David, I saw a video clip along this forum, but it was showing how to replace the entire dash. I don't think it was the same video that you were referring to, but I could be wrong. Can you please post the link to your clip? I was just quoted $5k to replace the dash at the Dealership in Dallas area. Crazy! It's out of warranty. Thanks, John
I just added a post under XF bubbling leather on dashboard which explains the whole problem .It can be fixed by removing dash top then peeling back leather and re gluing . The leather is then stapled around the speaker opening and the leading edge of the dash near the windscreen vents which prevents the leather shrinking and pulling the adhesive backing off the dash . Look up my post and look at the You Tube video titled XF Jaguar dashboard leather bubbling and you will see precisely how to fix the problem . David T
#43
I just encountered the same problem with the dashboard. My 2010 XF has 58,000 miles on it. The dashboard was fine and last week, I entered the car and noticed that the dash had bubbled up near the window by the front speaker. The temps were very cold for a few days in Illinois (-13) saw its just not a heat related issue. I also saw this on a 2009 Jaguar that was for sale in the Jaguar Dealership lot. This seems to be a common problem for Jaguar that they are aware of. I am in the process of going back and forth with the dealership and Jaguar as the Pre-Certified warranty is still in effect but the original manufacturer warranty expired three months ago or 8,000 miles ago. I am really surprised that Jaguar did not address this issue.
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
![Icon Mad](https://www.jaguarforums.com/forum/images/smilies/icon_mad.gif)
#44
To find the Video that shows how to remove the XF leather topped dash to re glue the leather and staple the leading edge and around the speaker vent you just log on to U Tube and enter in the search field " Jaguar XF dashboard leather bubbling repair " and the English Video will come up and show you how to remove the dash and then when it is out re glue and staple the leather and then re assemble it back into the car. It is an excellent video and the only way to repair the problem .
DavidT
DavidT
#45
DavidT
DavidT
DPK (08-26-2015)
#47
#48
From what I have been through - if the leather is only bubbled, it 'may' be able to be pulled back and reglued, but it might be easier to put a pinhole in the leather and put glue in through a syringe instead of pulling back the leather.
If the leather is peeling back from around the center speaker, it is shrinking, and it's a 99 to 1 shot of re-stretching the leather, which would then require new glue and stapling the leather down where it wraps around the dash.
If you buy the entire dash from a dealer - figure 3000 bucks. I have seen it as low as 1900 bucks online.
The next method is taking your dash off, covering it with suede, and putting it back together.
Easiest fix is to cover the dash with a high end dash cover for 40 bucks and tell yourself it looks fine.
#49
My wager is that you'll really wish you didn't try that old trick. It will most likely look much worse than the original bulge when you're done. Kinda like those brainiacs that try to glue or thumbtack their falling headliner.
#50
#51
#55
Hello McLaughing, I was wondering if you still have this item and if you know if this would also fit the 2009 XF Premium Model? If so, how much are you asking for it?
Thanks,
john
johnmart0000@yahoo.com
#56
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
I came back to Florida after a month in the UK to find the dashboard had pulled away and wave had appeared . This is a low milage car 12,000 and has been garaged . Jaguar US claim this is fair wear and tear, I disputed this as the local Jaguar dealership tech had tole me it was an adhesive issue with the early XF range. After numerous calls to Jaguar they offered 50% of the repair cost almost $2000. This is a fault in manufacture so I have taken it up with the Coventry factory. Not sure why we should pay for something they cause during the build process. If any one has the same issues with there Jaguar , suggest they contact me as a class action or a direct case against Jaguar corporate may force them to issue a recall. This would primarily effect owner in hot climates
#57
Robert Pearcey (07-18-2016)
#58
#59
This seems to be one of those things that everybody knows but JC say they have never heard of so don't understand why a recall or TSB would be necessary and why 50% is considered generous. Jaguar aren't the only ones, Audi were worse with their rubber coated switchgear which went goo overnight and were impossible to rectify other than replace. If the goo didn't get you then the rubber coating just flaked off and Audi blamed it on "sweaty fingers". After twenty odd years of Audi ownership it was one of the last straws.
I get that Coventry can't easily replicate the Texas climate (I was told by local indie Jag Techs it's more heat than direct sun/UV issue) - but when a small portion of your customer base run into edge cases due to where we're at, don't play silly buggers, do the right thing and fix it.
#60
The consumer can not be blamed for a manufacturing defect thus it is Jaguars responsibility to correct a mistake made in design. The modified dash has staples. Jaguar continued to fit the old version even after they became aware of the fault. I had a Mercedes 500 for 15 years in Las Vegas when I sold in dash was perfect. May I ask if you work for Jaguar as that is the only way I can imagine you came up with your reply.
