Can you adjust a individual headlight?
This is a simple fix, and this thread also reminded me that I needed to do the same. There is a green plastic adjuster crew right behind your headlight.
Using a 6mm allen key/hex socket turn it clockwise for up, counter-clockwise for down. Yours may look a little different than the picture, I have the 5.0SC engine which has air boxes on both sides, but still should be easy enough to find. If you can, do it with the headlights on and shining on a flat vertical surface in as little daylight as possible. Makes it easy to see how much you are adjusting the lights.
Leet8845 (10-06-2017)
I wasn't aware there was a L-R adjuster screw.. The one I circled in my picture definitely is up-down though.
