CEL - 2 1/2 hours from dealer
Any good OBD II reader should be able to pull the codes. So the parts store should be able to help you.
You should check and ensure your gas cap is tight first. This is the most common reason for CEL. If you don't clear it with a reader, it should go away after several start cycles after it's properly tightened.
If not that, then you will need to pull codes and figure it out. Good luck.
Received 2,192 Likes
You know maybe 1 day jaguar will go GM's route and be able to see what codes are stored with ON STAR and tell you if you need to come in now or can schedule for a few weeks down the road.......hey just remember I said it first
yes as long as the codes are obdII generic and not Jaguar specific. Jaguar also uses 6 digit codes now and not just 4. But hmmmm09 XF sc. I would guess and say p0171, p0174(lean engine, vacuum leak back of the air inlet elbow under throttle body, or possibly p0128, thermostat failure for coolant temp below threashold.
You know maybe 1 day jaguar will go GM's route and be able to see what codes are stored with ON STAR and tell you if you need to come in now or can schedule for a few weeks down the road.......hey just remember I said it first![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks again for the help.
trosty
26
12-18-2022 06:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
09, 2009, antifreeze, cel, codes, coolant, elbow, induction, jaguar, logged, p0171p0174, replacement, sc, threshold, xf
