Check Engine light 09 Jaguar XF Supercharged
Most all "critical" codes will remain in memory till cleared, so I would assume this to be a lesser CEL error that clears itself when you shut the car off (educated guess). Maybe low oil, overtemp or some such thing?
Next time the light comes on, see if a code can be read before you power down. Many auto parts stores can read codes for you for free.
BOL
Vince
BOL
Vince
BOL
Vince
BOL
Vince
Thanks in advance
You'd have four O2 sensors. Two for each converter. Your car has a left and right hand converter. See the following..... 2009 JAGUAR XF Parts - Direct JPLV Porsche Parts.com
They put one sensor in front of a given converter and one at the exhaust of each converter. Then the ECU compares the reading of the one in front of the converter to the one at the rear of the converter and determines if the converter is doing its job...or not.
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
SingBlueSilver
08-27-2015 02:20 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
