Check engine light came on
Received 2,190 Likes
the seal that leaks is on the brake booster pipe where it goes into the supercharger air inlet. Its common only on the 4.2 supercharged XF's so far. So common parts are now backordered and we're seeing about 4 cars a week. I have one in my stall waiting on parts right now. Its nothing more than a deteriorated rubber o ring inside the air inlet tube and very hard to replace the inlet. If dealers dont know theyre not gonna look there because if you follow the bulleting in referances more the super charger to intercooler air ducts. I havent seen any of these leak so far on the SC engines.
The oring is right next to and downstream od the EGR valve inlet to the engine. The heat from the EGR kinds of accelerates the life expectancy of it and they get hard and break apart. Not to mention that even replacing the parts doesnt always seal well and Ive been in the habit now of a couple wraps of teflon tape around the plastic pipe where it goes into the oring to increase sealing.
The following 2 users liked this post by Brutal:
Panthro (10-27-2016),
rigodepablo (10-17-2014)
P0174 = Lean condition on Bank 2. It could be a vacuum leak but you'd usually see a lean light for both banks if it's before the intake. A lean condition on only one bank would usually be a leak in the intake gasket on one side. It isn't always the case though so check for leaks everywhere. The issue mentioned above could be the cause.
P010B = Comes up as MAF issues when I search online. Check the air filters. Are they aftermarket? If a K&N filter was used and had way too much oil it can clog up the MAF sensor. Try using some electronics cleaner on the MAF sensors to clean them. If they aren't K&N filters and the filters are very dirty replace them and clean the MAFs.
I'd attack the MAF issue first (P010B) as the MAF issue might cause the P0174.
Maybe. Generally you can track down vacuum leaks by starting the car, popping the hood, and listing for the hiss (if it's bad anyway). Otherwise, take the engine cover off and move the intake box/hoses around to look for broken hoses/loose clamps. If it's not obvious you can use a can of carb cleaner to spray possible leak points (all joints/hoses/gasket areas) after the MAF and before the upper intake. If the engine revs when you spray something you found the location of the vacuum leak. Carb cleaner is flammable and eats through paint though so be careful. Google how to find a vacuum leak and read a few different how-to's.
#30
#31
Thanks Blackcoog
The obd2 reader had one entry for P0174 and two entries for P010B
This car is ALL new to me, my girlfriend is on vacation and left it at my house to fix her wheels, but I'm finding out a lot more stuff, like the CEL, and I also checked the oil dipstick and it's a MIN! The power steering is at MIN too! Plus a few other things.
She scuffed and scraped all 4 volan wheels when she put chains on!
Here are some pics prepping them for paint last night, I've got my hands full for the next few days.
![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
#32
I took one of the air filters yesterday to look at the MAF and it looks fairly clean, the plan is to replace both air filters and clean the MAFs with MAF cleaner.
Is this the infamous brake booster seal that causes air leaks? The car is on jackstands at the moment, once I get it down, I'll spray it with carb cleaner to see if it's causing the codes.
#33
Ouch that would ruin my day I don't like to park near curbs. I thought mud flaps were over kill. She's luck they didn't beat the fenders. Maybe an SUV or crossing country ski's would be better. Go luck with the wheels. They may need professional refinishing and then a set of steel wheels for the chains.
#34
#35
I sprayed the brake booster seal or at least the part I pointed above with the red arrow, but I did't notice a change in idle. I changed the air filters and clean the MAF with MAF cleaner and cleared the Check Engine Light, it was good for about a day, and it's back again! Anyone have suggestions on what could be causing P0174 and P010B on an '09 XF supercharged?
#36
#37
BrentGardner
28
04-26-2024 03:08 AM
