Climate control panel
The panel isn't a complex part so its likely that if you get one from a donor vehicle of the same type and it'll probably work. If I were doing it, I would buy the part from a similar vehicle and try it because they are relatively cheap from your favourite auction site. If when you get the existing one out of car and its totally wrong you haven't lost much (you can always relist the unused part).
