Coolant always below minimum
Have a strange case on my XF 2011, the coolant warning never shows up & every other next day I am seeing the coolant level goes way below the minimum.
I opened the rack below, and found no visible leaks. It was dry. The hose pipe do not have any cracks either. I am mixing 50:50 ratio of Jag Coolant with Water.
Getting tired of filling the coolant every morning now, I am topping up every time I see it goes way below minimum. Is there any solution to this, I am sure being an old car the mechanics would simply recommend me to change the entire unit.
How can i check my own and gather info
1. Is the coolant sensor working properly
2. Any pressure problems or water evaporating out
3. Determine any kind of unusual leaks or self diagnosis
Take it to any garage with a cooling system pressure tester and have them test it. Laces a cooling system can leak. But a solvable issue
I wouldn't drive it until then. If it fails and drops the coolant you will warp and destroy the engine before you realize...
If low coolant sensor isn't working just replace header tank. Quick and easy. About $100 for the part. You can try and refloat / fix the sensor but prob not worth it
Alwann
09-23-2009 03:18 PM
