Coolant Leak behind engine
https://superchargersonline.com/2021...ger-oil-chart/
hartmandm (04-09-2022)
Thanks for clarifying the volume of oil for the supercharger.
Another question related to replacing all these cooling parts - I'm struggling to figure out the Jaguar part number for the rubber hose that runs from the throttle body, under the supercharger, to the rear heater manifold / crossover piece (for a 2013 XF 3.0L SC). I haven't been able to locate the hose on the Jaguar dealers' web site diagrams. I'd like to replace that hose and I ended up breaking one of the plastic clips that attaches that hose to the underside of the supercharger when I was removing the supercharger. So I'm trying to track down the replacement hose and determine if the replacement hose comes with those clips to attach to the supercharger, or if the clips can be ordered separately, or if I just need to cobble something together using the broken clip.
Thanks,
Mike
Thanks,
Mike
Thanks,
Mike
Thanks,
Mike
For future reference for those viewing this thread ... following up on my previous post looking for part numbers (for a 3.0L). The rubber hose that runs from the throttle body, under the supercharger, to the rear heater manifold / crossover piece had the part number DX23-9F813-AA on it. Some web research showed that part number associated with Land Rover part number LR041866. I ordered that Land Rover part number and it is also marked with DX23-9F813-AA and it is identical to my original Jaguar hose. The same research identified the clips for attaching that hose to the underside of the supercharger as Land Rover part number LR011221. I did not actually order those clips, so I can't verify for sure that is the correct part number. I plan to try reassembly without using those clips.
Thanks,
Mike
Thanks,
Mike
The following 2 users liked this post by hartmandm:
Reaxions (05-02-2022),
VicVegas84 (04-30-2022)
EsRay
16
10-08-2018 10:05 AM
