Coolant Level Low Alert???
Old 11-21-2018, 08:35 PM
PJ704's Avatar
I opened the cap today and this is how it looks inside my tank.
The fluid is filled to the max line but the black circle is at the bottom. Is the black circle the float that you guys are talking about?
  #42
Old 11-22-2018, 02:03 PM
Received 2,192 Likes on 1,358 Posts
no, that it the retainer that keeps the float(white piece under it) down
  #43
Old 11-27-2018, 08:21 PM
PJ704's Avatar
Just so that I understand you better, when you said the white part is the float. Looking at the picture, is the float size is the blue circle or the green circle part?
  #44
Old 11-28-2018, 07:29 AM
jmurraywv's Avatar
It is the blue circle.
  #45
Old 11-28-2018, 08:59 AM
Bigg Will's Avatar
Although I hate too, I have to agree with Lotus on this one, Spend the $$$ and just replace the tank, as he say's the plastics are consumable on these cars.And as Brutal has said rigging something like this is just crazy on an XF. $100 is still WAAAY cheaper than an engine, it only takes about an hour to do.
  #46
Old 12-06-2018, 08:46 PM
PJ704's Avatar
Is this as simple as siphoning the coolant out into a bucket, then unplug a few hoses, unscrew the tank, put in new tank, plug hoses back in, refill the tank with the original coolant? Once I install the new tank, how will the red sensor clear from my dash?
  #47
Old 04-15-2019, 05:35 PM
PJ704's Avatar
I changed out my coolant reservoir a few months ago. All was well until the same coolant level low warning sign appeared on my dash again???
please help.
  #48
Old 04-16-2019, 02:21 AM
santer's Avatar
Did the replacement have a new external coolant sensor?
  #49
Old 04-16-2019, 09:29 AM
PJ704's Avatar
The sensor is built into the reservoir if I am correct. There are no external sensors. I checked and did see that my coolant was really low. I did not see any leaks anywhere so where did all the coolant go??
  #50
Old 04-16-2019, 10:20 AM
santer's Avatar
There is an external sensor, some tanks are supplied with it installed
https://www.sngbarratt.com/us/#!/Eng...6-49c970e5e030
If this was the first check then the level may have adjusted itself
Maybe fill to level and watch daily
If you added fluid did the low level light go off?
  #51
Old 04-16-2019, 06:07 PM
PJ704's Avatar
I believe my tank has a built in sensor but I could be wrong. All there was is a 2 hoses and a plug I had to re-insert. Also, I added fluid and the light went off. But where did the old fluid go in the first place?
  #52
Old 04-17-2019, 01:39 AM
santer's Avatar
The tank has an inbuilt sensor and an external sensor, possibly the plug you mention
If you changed the tank, topped the fluid up, drove it then the first time you checked it the fluid was low, this can happen.
If you then top the fluid up and it still keeps dropping then obviously try to see where it is going, otherwise it should hold the level now
I would check the tank daily until you can see if it is holding the level of fluid rather than waiting for a sensor to show anything
  #53
Old 04-17-2019, 08:52 AM
PJ704's Avatar
Hi Santer,,
Yes I replaced my original with a new oem tank. I did top it off and am monitoring it daily now. You said that the fluid can be low the first time after a fluid top off. Why is that?
  #54
Old 04-17-2019, 09:48 AM
santer's Avatar
Probably some air in the system
  #55
Old 04-25-2019, 10:13 PM
PJ704's Avatar
Okay so it's been about 8 days since I filled it to the midway mark between max and min and now it is slight below the bottom of the word "Coolant Range". I think there is a leak somewhere. What do you all think?
  #56
Old 04-26-2019, 02:54 PM
lotusespritse's Avatar
The coolant systems don't use up coolant. If you have less coolant than before, you have a leak.
  #57
Old 04-26-2019, 05:33 PM
PJ704's Avatar
Any idea where the leak can come from? Is there a usual area or culprit I can check?
  #58
Old 04-30-2019, 11:19 PM
PJ704's Avatar
Anyone???
  #59
Old 05-01-2019, 05:38 AM
leadfoot4's Avatar
Remove the underside "belly pan", and see if there's any liquid contained in it. If so, then start looking for any sign of liquid dripping from one of the coolant hoses, radiator, etc. If there's no evidence of liquid, then you have an inordinate amount of air in the cooling system. When you replaced the reservoir, did you run the engine, with the heater on at max temperature setting, and the radiator cap off, for at least 10-15 minutes?
  #60
Old 05-01-2019, 08:52 AM
Get a coolant system pressure tester.
https://www.youtube.com/results?sear...cooling+system
Quick Reply: Coolant Level Low Alert???
