Coolant Level low, What's the proper coolant?
Hey, so my Jaguar just got the coolant level low light.
After some forum searching I'm probably gonna replace the tank/the float.
Can someone tell me what's the proper fluid to fill it with?
Can't seem to find it around here, thanks in advance!
Received 2,646 Likes
It is always helpful to provide the MY and other vehicle details when requesting help from the forum.
The vehicle Owner's Manual indicates the correct coolant to use that meets Jaguar specifications. Avoid mixing different types (colours) of coolant and be sure to properly bleed the system to removed any air that may be present.
Received 3,226 Likes
You need the extended life coolant (usually colored orange and in a container with a bright orange cap), available from most or all of the name brands. Do NOT under any circumstances use the "regular" coolant you have been using for many years, no matter what brand.
Received 2,263 Likes
On my 2006 S-type 4.2 with mileage in the teens, I get a low coolant message often at start up. The reading is false and goes away after a block or two of driving. I assume something is getting stuck causing the warning.
I have posted this in case you are correcting a problem that does not exist.
I use this one: Penrite 6 Year Anti-Freeze/Anti-Boil Concentrate - 5 Litre - Supercheap Auto Australia
Meets the Jag spec and only $55 AU (around $45 US) for 5 litres, so you should be able to get the correct spec coolant in the US for much the same price of $9 US per litre.
If you look at the coolant level you may find that it is actually low when you start. As the engine warms up it expands and might then read as sufficiently full. Worth checking when the engine is cool and topping up towards the top of the min-max range to see if that fixes it
I use Redline shock proof synthetic in my E diff.
