Cooled seats
Hey boiler.....
On the seat backs (squab) its a rubber below to a PU mat and 10mm thick air distribution pad, this then blows through the trim cover which has sewn in a 15mm thick softer air distribution pad to the perforated leather...........the seat cushion os the same but no belows........just a duct molded into the B surface of the foam.........on the Jags never heard of any colapsing ducts as the angle of exit from the Amerigon blower unit is quite steep......the duct just compresses along its length rather than squashes in section......
hope this helps!!
hope this helps!!
Thank you
I noticed that my cooled driver's seat works great when it's on but it will only run for about 1-3 minutes and then shut off. The display shows that the cooled seat is still on but but the fan turns off. It won't turn back on unless the car is restarted. I saw that someone else noted the same issue. I pulled the filter out and blew it out with compressed air but it wasn't dirty. I'm not sure what would cause the fan to shut off. I might try running it on low to see if there is a difference. The seat heater doesn't work for the driver's seat either but I don't drive it in the winter so I didn't notice it until recently. The passenger seat appears to work normally.
The following 6 users liked this post by boiler:
BigTurk (10-24-2019),
fabfive (09-22-2015),
Long Islander (10-15-2015),
macboots (12-30-2015),
Panthro (06-16-2016),
and 1 others liked this post.
Could you please explain how you replaced the filters? Also, I went to Rockauto's web site and I didn't see anything listed as "SHO." Is that a Taurus?
And the after market absolutely does carry them
https://www.rockauto.com/catalog/mor...nid=514&jpid=0
#30
#31
I googled the part # rock auto gives and the ebay ads all show the same picture
Ford Front Seat Filter Left 7L1Z19E880A | eBay
FORD OEM Front Seat-Filter Right 7L1Z19E880A for Sale - emgCarTech
#32
#33
I took a look at the seat cooling fan filters and sure enough, they are very easy to remove with just a twist of the hand. Both of mine looked to be very clean after 6 years however. Also, I checked the owners manual service section, and while it requires that the cabin pollen filter be changed every 2 years, it doesn't say anything about the seat cooling fan filters. Where did you guys read that these had to be changed every 2 years? I'm inclined to just take them out, soak them in dishwashing liquid, rinse and let them dry in the sun before reinstalling.
#34
I was wondering though - is there a filter for the upper fan that goes to the seat back or do they both suck from the same place?
#35
Mine did too. I did the dishsoap spray on them and they ran pretty dirty despite looking clean. I don't see any reason why not to do it, myself. As long as you're gentle with the wash process and don't introduce extra big holes, it shouldn't affect it.
BTW, the filter was dirtier than any of the others in the car. I'd recommend everybody get in and do this if you've noticed your seat back cooler sucks (instead of blows).
The following 3 users liked this post by n8ertot:
#36
So I chased a white rabbit down the hole... Turns out the filter is on the fan that's built into the back of the seat. Bonus is that I figured out why my seat back fan didn't seem to do much. Turns out the duct was busted and it seems like it's probably something that's really easily broken. This was a bit of a PITA, but I took looooots of pics. So I'll do a DIY and post a link to it here after I'm done.
The following 2 users liked this post by n8ertot:
seamagineer (08-23-2016)
#38
So the Rock Auto link indicates Motorcraft FS104. Amazon pics and reviews show that the current version of the FS104 does away with the fiber material, and just replaces with a coarse plastic screen. This new design won't stop dust from going through, but will protect the blower from FOD (foreign object damage) to an extent. Makes me think we'd be better off going to Home Depot and buying some bulk filter material and replacing the fiber part ourselves. I'll investigate this further some day.
Last edited by Escolar; 12-30-2015 at 03:16 PM. Reason: Original response was redundant. Now adding value. :-)
#39
I'd think they'd want to make sure it got as much particulate out as possible, considering the air is being supplied from the foot area and there's really no way to clean out the seat holes if they get plugged.
#40
i've yet to experience any heat in bottom or back, even thought the dash screen says it's on high.
