Damaged rear after a bad spin....
Want to experiment with the car? There are track days just for this type of practice. Experienced performance drivers will show you how to dos and not to dos. Then when you are on the street you will understand what special treats you have in the car and can control what was one time unexpected. Good Luck!
I have tried a 100 times to pitch my 09SC in sport and traction control off, I believe its called dynamic mode engaged. unless we are talking about taking a turn to fast and the rear end breaking loose I dont get it. my car no matter how hard I hit the gas and pitch it sideways, even in the rain, the engine will pause and only one tire will spin.
its pretty damn frustrating really, until the weight of the car has equaled out, meaning I am going straight, the car will not go full throttle.
I even tried it in several empty parking lots and the front end will wash out before the back end with the steering wheel turned all the way to one side.
ive been wondering if traction control is actually disengaging cause it still works!
Regardless, Sorry about your car, hope all is well again. I would be pretty happy with the price of that repair.
Yes n8ertot is correct.
The traction control gas 3 settings.
Full on, won't let you do much more than a chirp from the rear.
Hold trac button down for 3-9 seconds, "trac" mode is on, and you get a little bit more spinning but the car still won't let you slide sideways.
Hold trac button down for more than 10 sec. "D.S.C." (Dynamic stability Control) is off. No driving aids at all.
Trac control OFF
If you're trying drifting you should try with dynamic off and on. We ran at the academy on the "wet" track and the cars perform very different in the two modes even with trac off. Have fun!!
I did something like this earlier today, first time since I bought the car, oh what fun I had today. Makes a big difference.
#28
Most modern cars will handle a track day - I've taken mine to one, and as long as you take good care of the car it is doable. There is plenty of info on dos and do nots for track days on the internet so I won't repeat it all here. The biggest gotcha with non-XFRs is the lack of a LSD which can make rear end control more tricky.
May I suggest CarLimits for a start? They do either a 50 quid day (shared) or a more expensive option with 2 or 4 people for a day (the former option is currently unavailable until fairer weather). It's cones on an airfield and a single participant on a circuit at a time so it's very safe, and it's designed to teach you about the limits of your car. I've done the 50 quid activity and I'd recommend it. I'm very tempted to try the more dedicated option now.
Otherwise there are many track days in the UK based on old airfields, these naturally have large runoffs which avoids damage. There are still other people to hit though, so track day insurance would be a must.
As mentioned by other members a nice large empty (kerb-less!) car park is probably your other alternative... Be careful out there!
Simon
David Missouri
02-02-2017 08:31 AM
Jaguar Forums Editor
Jaguar Press release
11-10-2015 10:38 PM
11-10-2015 12:38 PM
