Dash issues
That is where mine failed. A triangular section (about 3" on each side) with one side next to the center grill and another side close to the window failed. It bubbled up and revealed the padding underneath where it met the grill. Warranty was going to cover it, but it needed a complete replacement of the leather part of the dashboard (so I was told).
wannajag (10-27-2012)
Just bought an XF Premium Portfolio last week. The leather is pulling away from the windshield just right of the center speaker causing a pucker. Dealer is going to replace under warranty. Also found hair line cracks in wood on console. Dealer says he may have to replace entire set of wood trim because they are matched sets. In any event it will be replaced one way or another under warranty.
I had my dash fixed on my 2011. The issue is a factory install problem or product defect. Nothing an owner has any control over or caused.
Hopefully the new one was installed correctly or a better product was used that will not be adversely affected by the heat/sun.
Lots of cars in Texas do not have dash issues, so if Jag dashes fail, Jag should fix.
the darker the color the more the failure, dont want it to fail, dont park or drive in the daylight hours Dracula. The dashes are cover under factory warranty. Its seat wear that usually entails the "warranty handbook statement" not the dash. Ive seen a couple 2012's pull. But nothing like earlier. Alledged to have more material, glue and staples now.
