Dashboard problem
Dashboard problem
My _09_ XF Supercharge XF dashboard center section between the dials fades in & out. Dealer says don't bring it in till it is mostly permanently off. Easier to find that way. Anybody have information or experience with this problem? Can be off for 15 - 20 minutes & on the rest of the time. Not critical; butI like to be prepared. Some report electrical problems with '09's.
Hey Tchamp - I have a similar issue on my 2010 5.0 SC. I haven't got around to fixing it but have done an extensive amount of research/troubleshooting. As GGG mentioned the Audi's have a very similar instrument cluster LCD fading issue on the B6/B7 models. The cluster on the Jag is made by Visteon, not sure about on the Audi's.
On the Audi's users have noted that the issue was usually heat related. During hot weather the issue would get much worse. I have been able to replicate those issues. Ultimately, I believe it's a LCD capacitor issue, which on the Audi clusters were integrated into the LCD flex wire (making the whole LCD unit have to be replaced). There was a guy on the audi forum who purchased bulk replacement screens and did the swap for fellow users.
Unfortunately, the Jag community is not as large and replacement parts will be harder to find. I'm not technically inclined enough to troubleshoot the dash at a chip level so what I've decided on is purchasing a used instrument cluster and just soldering over the EPROM that holds my mileage and security data. As per:
https://www.jaguarforums.com/forum/x...-fault-141855/
Shout out to fletch106 for pioneering the EPROM replacement option.
SIMPLY SWAPPING THE USED CLUSTER WILL BRICK YOUR CAR. Those can only be reprogramed new or have the EPROM resoldered beforehand.
The two things I have to tackle now are:
-removing the instrument cluster
-finding someone to resolder the EPROM chip
-reinstalling the cluster and have everything work again
Best of luck! and happy I can finally help somebody after a year of lurking :P!
tchamp (06-06-2017)
fixed mine------at least for 1 day ----pulled it out ---sprayed electronic cleaner on circuit board and 2 connectors and now it works-----------I have a spare used it to experiment --took it apart .lighting is all led ---20 +- for each gauge and 30 +- for center ---message center is a piece of glass with a ribbon connector ..also gauge pack is for each car has to be programed if swapped . I tried this ---------- installed and car did nothing and I mean nothing --will try to experiment further since I have spare gauge and car-------thanks
there are companies that specialize in fixing clusters. contact them to see if they can do it.
i have used this company before for a lincoln (close relative of the XF): R. T. Grim Company - Automotive Electronics, Instrument Cluster
they fix more than what they show on their website, so you have to call them.
having your unit repaired avoids all the craziness of transplanting a new or used dash.
