Do the doors auto-lock?
I have a 2010 XF Premium. You must lock the doors before you leave the car. The steering column up/down, in/out control has a position that automatically moves the wheel up when you open the drivers door. There is no provision to automatically move the seats when you open the door to facilitate ingress or egress (not that this is a good idea since this may cause a seat to crush a rear occupant's feet if the driver exited the vehicle whilst there was a rear seat passenger).
Hope this helps.
Hope this helps.
Sorry, I probably should have been clearer in my response. When you exit the vehicle (XF Premium), you can keep the key in your pocket and press the external button next to the door handle on any of the four doors to lock the doors. What it will not do is automatically lock the doors as you walk away from the vehicle as I have seen some other manufacturer's vehicles do (I believe this function is an option of some Kias, for example).
So called keyless operation allows you to enter the car, start it and lock by pressing the external button next to the door handles with the key in your pocket and does not require you to use the physical key. If you lose the battery then you can use a key to enter the car via a pry off cover next to the door handle on the drivers side and then insert the fob into a slot on the lower right on the dashboard. Inductive coupling allows the key to function while in the slot even if the battery is flat/discharged.
Hope this helps.
Hope this helps.
Some keyless entry systems do not require that you touch the car either when entering or leaving. Corvette has such a system.
If the electric locks fail there is an aluminum conventional key in the end of the fob which will open the car or trunk lock mechanically.
The docking port to use for the fob if the car won't recognize the key in your pocket is to the left of the steering wheel low in the dashboard near the knee protection, for LHD cars.
On my XF it will automatically lock after a certain period of time. I have tested this because when I walk away and come back later, the security alarm light is activated and walked up to the door without the keyfob to see if it was locked. It was locked however the alarm went off (which is really annoying). The dealership told me the automatic lock function has to be enabled in the security settings. Apparently it comes turned off by default.
Received 2,190 Likes
on my xf it will automatically lock after a certain period of time. I have tested this because when i walk away and come back later, the security alarm light is activated and walked up to the door without the keyfob to see if it was locked. It was locked however the alarm went off (which is really annoying). The dealership told me the automatic lock function has to be enabled in the security settings. Apparently it comes turned off by default.
Set Passive Arming on and left the car alone for over an hour. Walked up to it without the fob and opened the door. It was not locked and the alarm went off.
Manual even says "car does not automatically lock".
I have a 2010 XF SuperCharged if that makes any difference.
The passive arming option makes no sense with out auto-locking.
The only "auto lock" function occurs if you unlock the car but do not open a door or trunk lid. The after 30 seconds or so the car will re-lock itself. This is very handy f you are in the habit of accidentally pushing the wrong button on the remote as you walk away.
The passive arming is perhaps for use when picknicking out of sight of the car with a child or pet left in the car with all the windows open.... I cannot figure out why anyone would want to use that feature.
Or, perhaps it is intended for those who like to leave the car unlocked in the garage but would like the alarm to set itself. I thought of that but then immediately thought of the probability of forgetting this feature and setting the alarm off every morning....
It's a mystery.
It's a mystery.
It's a mystery.
It's a mystery.
I thought you could set it where it auto-locks after 30 secs. I'm pretty sure my car does that. I usually press the button but I have closed the door and watched it lock itself. I'm going to have to try that again just to make sure. But I thought that was a feature you could turn on and off.
Neogod has the passive alarm function enabled. Indeed, with the passive alarm function enabled, the alarm sets automatically after about 30 seconds when all the doors are shut and no key fob is inside the vehicle. The doors remain unlocked but the fuel door locks. If the doors or trunk are opened and no key fob is near the vehicle, the alarm will activate. MY 2009 MY allowed owner enabling of the passive alarm funtion. For the 2012 MY, only the dealer can enable it. Don't know about the 2010 and 2011 MYs. This function provides protection in the event that someone forgets to lock the car. It can also be deliberately used for areas subject to theft attempts of car contents to eliminate forced-entry vehicle damage.
