Door rattle
#41
My 2012 XF has been in for service for this same issue on two occasions in just the past 4 weeks. My 2009 was very tight and never had any issues but my new XF has only 2k miles and it sounds like the doors are ready to fall off. It really has taken the enjoyment away from owning the car. Going around turns in parking garages is the worst.
Interesting, I was going to chime in that my 09 has no signs of this issue.
#43
Everyone
Update. Just picked my Jag up (for the 6th time) for the creaky doors issue. Apparently my service guys learned that they have been focusing on the wrong seals. A Jag rep was in and told them this has been an issue with cars primarily in the UK. The seals causing the noise are the upper door seals not the inner doors seals. They ordered and installed the new seals yesterday and I just got my car. So far so good.....fingers crossed. Hopefully this is it this time and maybe we ALL will have a viable solution.
#44
#46
hey brazz good to hear you are getting somewhere.
mine noises havent come back after the fix.
but very interesting that i received a phone call from the dealer stating that they still want to change the seals as they were just advised of another fix.
sounds like it is an issue everywhere around the world and hopefully it is a fix not a fluff up to keep you going in and out of the dealers.
good luck hope we hear none of those noises ever again.
#47
#48
#49
For my XF, it wasn't the seals causing the noise. I had minor squeaking in generally the same place, but it turned out that the noise was where the leather trim on the door and the dash meet when the door is closed, not the seals. I put a little silicone where the leather trim makes contact and problem solved.
#50
Back again for an update seals just got changed as well like brazz after also adjusting the doors perfect not the slightest noise ....
So for everyone experiencing the same problem ASK FOR THE FIX......
it is now noted world wide that there was a problem with creaking seals on 2012 cars..
#51
Received 2,190 Likes
Jaguar released a squeek and rattle kit recently with differant type of lubes and sprays for things just like this. Seals, door panels etc. when you have noises coming from seals and door panels where they touch/rub, contact/ You can get noises as ya'll have described. I have used this kit on many occassions now and it works perfectly and permanently every time if you identify the area/part that is causing the noise. I use primarily 2 sprays in the kit and I can tell you when they say it lubes and stays without coming off, they meen it. I made the mistake of getting too generous once and got the rubber seal spray on the floor of one of my lifts. Despite repeated cleaning, it is still slippery, not oily, or wet. Its just slick and its been months. you know those tv ads years ago about squeeky clean dishes? yeah the seals and door panels do the same thing, the sprays, and lube pens are aerospace dry lubes that leave nothing visible and work great. You just use differant products and applicators for the surface and material youre working with.
#53
Just picked up my XF from the dealership with the new seals installed on all 4 doors. The car was super quiet on the way home. Let's hope it lasts. The dealer said two other XF's have had the same issue and have something in common with mine. They are all black 2012 XF Supercharged models. Even the color is the same.
#55
Hunnenkoenig (03-08-2024)
#56
#57
I had to take mine back 3 times after they replaced the seals because they were coming unglued. Good Luck.
#59
Here are some pictures of the "correct" and "wrong" seals... Hopefully this helps others with the same issue with less trials..
Attachment 20188 - Correct seals causing noise - replaced
Attachment 20189 - Incorrect seals, not causing the noise
I have a 2010 model year XF, and it would seem I am the only person from the UK experiencing this issue on this forum.
Can I ask the Seal that was replaced, was it the seal that goes right round the door and just the strip along the top of the door, which is part of the chrome strip which sits on the utside top of the door? Also would it be possible to provide me with the details of your dealership in the U.S, so that I could contact them in order to provide some inormation to my own dealer in the UK on how to rectify the problem.
Many thanks for your help
Regards
Keith
#60
Regards
Keith
Regards
Keith
