Driver's door (RH) power window switches and mirror switches not working
All of the switches in driver side panel suddenly stopped working. Any idea that is there some fuse for that panel? If there is, where it is located?
Door locks work, mirrors turn when I lock the doors.
I investigated a little bit more. It seems that light (that turquoise light in door panel) is working normally. All other windows are working normally and nothing else seems to be a problem at the moment.
There are no lights in driver's side switch panel, and any of the switches are not working...seems to be power issue of some sort.
Simon Chapman (01-23-2021)
Makes two of us and I haven't found a solution new door module and new switch module did not resolve, wiring checks out OK and no fuse issues - this has got so annoying I may sell the car - sick and tired of basic sh*t not working because of computer BS - and this is 100% computer driven so if it decides not to talk there isn't jack you can do. Only think I've not done is put a scope on the comms.
The car is a blast, but electrically its a damn nightmare - battery on charge for a week and still throwing low voltage warnings for a near new battery too - I can't leave this car in an airport - sometimes the media centre doesn't shut down - sometimes it does it depends what mood it is in, the roof lights and glovebox entry have a mind of their own.
Fix which topic - stupid battery management or windows ?
I resolved my window by replacing the door module on the drivers door, there is a lot of confusion in items available what constitutes the 'drivers door' module and many vehicle salvage yards get it wrong - confounded by the mix of US and UK stuff out there, a clue for me that I did not figure out originally is the door mirrors - only a correct drivers door module can control them, you may allso notice that the 'lock' button doesn't work on the defective door. The passenger and drivers modules are not interchangeable but they will fit in either location. There is not much you can do to diagnose electrically, the door modules are 100% communication driven especially the drivers door master switches. The best diagnostic I found was whether my iCarSoft could detect the door module, if it can't check all the connectors or replace the module, if you can detect the module try to monitor the status of the
The first module I got was grey in colour, this didn't work, the one I finally got was actually all black and this did, the numbers on the modules made little sense either - the number is different from the original but it works - go figure that one. It also seems to be the case that all four modules must be functional for the 'master' switches to be functional
With me it was the top left 10amp fuse in the right foot well (drivers side RHD, passenger side LHD) if that fuse goes then the panel doesn't work🤷
Deany Boy
02-06-2018 02:32 PM
jloktalGst
09-10-2014 08:40 AM
