The pinpoint tests for this scenario from the Workshop Manual are limited to checking the harness for continuity and powering the fore/aft motor directly to eliminate component failure:
Beyond this it becomes a matter of checking for fault codes but this requires Jaguar SDD (Symptom Driven Diagnostics).
Seat Modules are a regular problem with several Jaguar models. Fitted beneath the seat cushion, they are subjected to frequent flexing in normal driving and this often breaks tracks on the circuit board. A method of checking modules on XJ and XK models is to (temporarily) swap driver and passenger to see if the fault moves too. I don't know if X250 is the same but Jaguar tend to replicate design principles across models and it would be odd if the XF is different.
