Dynamic mode does not work
Can anyone point me in the right direction regarding Dynamic Mode fault message when button pressed? Also paddle shifters do not work in S mode.
Car drives perfectly in regular Drive mode.
Thanks for any help
__________________
2009 XF 4.2 SC
Thanks for any help
__________________
2009 XF 4.2 SC
Welcome to the forums JJMcJay,
I've copied this question from your Intro to X250 forum for advice from members with the same model.
Simplest thing first, Check the 10A suspension fuse (F36 in the Passenger Compartment Fuse Box).
The system is controlled by an ADCM (Adaptive Damping Control Module) which receives signals from the vertical acceleration sensors to control the damping characteristics of each damper to give the optimum vehicle ride. A possibility is one of the Acceleration Sensors is faulty. You really need diagnostics (Jaguar SDD or equivalent) to troubleshoot this for relevant codes.
