Dynamic Mode - placebo effect?
Dynamic mode (the flag button), does different things in different trim models.
My 2010 V8 Premium (non-supercharged), all it did was make the throttle response for aggressive (touchy). Since it is a "throttle-by-wire" system, it made the throttle pedal less linear and front-loaded the pedal. I am also assuming it altered the fuel map slightly.
My 2013 V8 Supercharged takes that once step forward by stiffening up the shock absorbers. I really see the difference on the highway. If you are cruising at a steady speed, turn on the dynamic mode, you will feel the difference. It is a bit more "connected" to the road.
