Dynamic Mode vs. Sport Mode
I took delivery of my 2014 XF 3.0 on Friday, and I'm thrilled with it! The dealer, and the manual were a little light on details between the Dynamic Mode button and Sport Mode on the gear dial.
I know that putting it into Sport Mode lets me use the paddle shifters, but that can be changed in the Settings, so that I can use the paddles in D also. So, I figure there must be more to Sport Mode than just the paddles, but what else could it do that the Dynamic mode button doesn't?
Thanks,
-Brian
Thanks,
-Brian
Thanks,
-Brian
Thanks,
-Brian
Others, please chime in and correct me if I'm wrong.
From what I've been able to determine, and this is for the XFR, when in sport mode it firms up the suspension, definitely changes how the transmission reacts by holding gears longer and always staying a gear or two lower than in Drive, and I believe it also makes the throttle response quicker (this may be just the difference in gearing that makes the power come on quicker - one gear lower).
Dynamic mode definitely makes the throttle response quicker and it seems to downshift quicker when on in Drive. It will not upshift when using the paddles (you have to do it). This is the mode I most often drive the car in as it gives me a little more lively throttle, but doesn't make the transmission be so intrusive as when in sport.
The main difference I've found between Dynamic mode and sports mode is the shifting. Dynamic mode will allow the trottle to rev a little higher before shifting, sports mode won't shift at all until you are close to redline. If you go to manual shifting, in sports mode, it will not go back to D. where as in dynamic if you leave the car in the highest gear for an extended amount of time, it will go back to automatic shifting just like in normal mode.
Also in sports mode, if you do go into manual, the car will not shift for you no matter what, so if you want to destroy your engine, you have the chance to do it.
I think an easy way to think about Dynamic vs. Sport is to remember that Sport only affects the transmission shift points (and of course enables the paddles), so it is a classic "Sport Transmission" mode. Dynamic, on the other hand, also somewhat alters the shift points, but also alters throttle response, presumably the braking response is supposed to be a bit faster, and if you have an adjustable suspension, will alter that as well.
yeah, yeah they do downshift when you slow down, probably just to make sure you don't stall the engine. I forgot about that.
Maybe this is also related to the fact that the car likes 2nd gear instead of going to 1st gear while using the paddles.
PolkNole
05-14-2024 03:36 PM
