ECU PROBLOM jaguar 2013 4 cylinder
JAGUAR 2013 xf 4 cylinder.
Hello . Please i have jaquar XF 4 CYLINDER 2013 .
this car started working 3 cylinder .i think from the begging is Coyle..i changed the Coyle but still not working..so u chsnge The ECU and i program it the ECU .. now the car just work minute then now speed ...when i pute the old ECU the car worke and speed work but 3 CYLINDER... so somwhen have IDEA about this ..thank you
Welcome to the forums Ahmed,
I have deleted your other versions of this same question from XJS forum and other threads here in X250 forum.
Have you had the error codes read? I expect you can hear the engine is only running on 3 cylinders but the error codes will confirm which cylinder is the problem and could also help identify the possible causes.
