Electronic Glovebox Fault
I expect you know this, but assuming this is one with the touch sensitive 'button' - it's not very sensitive... My dealer showed me that if you use your nail rather than the pad of your finger it works much, much better... Worth a try (I know this doesn't answer your actual question, but hopefully this helps)
I am also assuming you have an early model year (2009 or 2010) because I think they changed the design after so many people were having problems with it. I read elsewhere on the forum that you have to keep in mind, it is not to be a swipe, but to aim and move your finger directly at the rondel (?) head on, not from side to side. After using this method, it works every time for me.
It is designed not to open if you move your finger tip sideways even a tiny bit. It is a "touch" switch and not a "swipe" switch.
You must touch the roundel on the centre and it should pop open. If you are off centre or move your finger tip sideways at all it will not open.
The new push button switch is a disappointingly boring result of auto journalists and car salesmen who don't know what they're doing.
dmatthewman
09-30-2015 11:10 AM
