Engine check light coming on
Old 03-30-2016, 01:59 AM
Dean Kitching's Avatar
Default Engine check light coming on
hi, had the sv8 (118000km's) less than 2 weeks and the check engine light has come on twice now. I have an Autel code reader/scanner and there was 50 odd faults when I first read everything, but all but 1 disappeared after clearing, which from memory was the "lost communication with rear camera" which seems to work fine... but the check light came on again today, and I seem to be left with two "permanent" codes , from module 14 , "battery backed sounder"and 21 , "Lost comms with rear camera". While these are annoying, I doubt they set off the check engine light, but could they? I was a bit quick to clear everything and should write down all the codes I guess.... I have a 3 month warranty so want to get anything serious fixed... Is this model prone to thjrow a lot of codes?
TIA Dean
Old 03-30-2016, 04:41 AM
JagV8's Avatar
Received 4,533 Likes on 3,942 Posts
No but since you don't know the codes we also don't.
Use the warranty.
Old 03-30-2016, 02:53 PM
real pita to take it back 2 hrs to where I bought it...will write the codes down when the light comes on again,
XK_SL
09-04-2016 05:20 PM
MissyBeeS
04-06-2016 08:25 PM
Harry Dredge
03-15-2016 03:44 PM
hjt1948
03-05-2016 05:20 PM
amcdonal86
03-01-2016 01:28 PM
Quick Reply: Engine check light coming on
