Engine swap xf v8 5l
My engine finally failed after a left head gasket blew. I think replacing the gasket is too much of a job. I have found good used engines in the 4 to 5K I donīt know if new ones are available.
I understand that for 2011 to 2014 engines are same with letter B on 8th position on VIN number. Has anybody completed an engine swap before in this forum. I understand that removing engine is not
as complicated as removing valve head with engine in vehicle and that its reasonable job all considering and that no further computer work is needed.
Appreciate any comments.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20221110_123503235_hdr_905f6105c2a4cbd287dd9185b2773365094a2ec3.jpg)
You fixed 4!.Wow man Respect! Well if you can let me know the following.
1. It seems removal is straight forward as your picture shows. Remove Exhaust, Drive shaft...
2. Once you put new one in of similar VIN do you have to fiddle with software or something?
3. How many hour did you take to drop it and put it back in.
Thanks much and regards
https://drive.google.com/file/d/1-zzjWpxYZyL4Yo81G68g0uEBmgQiMVFU/view?usp=drivesdk
No ECU work needed.
Louie Dachshund
05-08-2019 02:18 PM
shawnethan
04-06-2013 04:06 AM
03jaguardown
General Tech Help
12-27-2009 11:08 AM
