ENTIRE Power System INOPERABLE - RESOLVED
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
2012 XF Portfolio: Was running perfectly, no error messages, etc. Drove to my son's house and turned the engine off, came out 30 seconds later and there was NO POWER, couldn't turn on the engine, interior lights not working, couldn't even open the glove box or trunk to view the battery compartment (did access it with the key). Is there a Main Fusible Link that might have blown?? If so, could you steer me to where it would be located?
Last edited by GGG; 07-06-2022 at 10:55 AM. Reason: Add 'RESOLVED' to thread title
Forgot to mention that. I replaced the battery about 2 months ago. The only other thing that I have done recently is install a "ecoobd2" device that plugs into the OBD2 port and helps (supposedly) to improve fuel and emissions efficiency. It was installed into the OBD port about 150 miles ago. But had not had ANY indication that there was any problems since then (mechanical or electrical). Could that be the problem?? When the power went out I pulled that unit out, but didn't bring the power back on!
Although NOT the cause, it's worth remembering the OBD2 port is permanently 'live' and leaving devices attached for long periods can discharge the battery.
Fast Cat
10-22-2014 10:25 AM
