EPB module problems (possibly)
Hi All,
A few times now my XF 2014 sportbrake 2lt wont start due to EPB error. failure..
Previous time(about a year ago) I replaced with new battery and with a bit of re calibration and much swearing it started. Whilst driving along the other errors cleared (abs, gearbox errors etc)
Happened again 2 days ago, so again I replaced the battery, and it didnt want to know this time. After further swearing and a John Cleese moment I started unplugging various connectors from the main fuse box in the boot, after disconnecting each one, one at a time I tried to start. Finally it started and away I went with no issues for about a day.
Until yesturday the same thing all over again, tried all the above and eventually gave up and got car picked up to local non Jaguar garage.
They are now saying EBP and Abs module need replacing at a cost of £2600.00
Bellow is a list of computer read out.
Patrol found the following fault code/s:System : Engine control - 5Z9 / Diesel EDC 17CP42 Status :P0088 - Fuel pressure system / system pressure. Error Message : Malfunction. Historical fault. Status :B10A2 - Crash signal. Error Message : Frequency too low. Error sporadic. Status :P0409 - Exhaust-gas recirculation sensor A. Error Message : Voltage above threshold. Historical fault. Status :P0512 - Request for starter triggering. Error Message : Signal too large. Error static. Status :P0070 - Ambient air temperature sensor. Error Message : Voltage above threshold. Error sporadic. Status :P0627 - Fuel pump A control circuit. Error Message : Open circuit. Error sporadic. Status :P0628 - Internal control module Fuel injection. Error Message : Short to ground. Error sporadic. Status :P0700 - Clutch pedal switch A/ clutch position sensor. Error Message : Malfunction. Error static. Status :U0300 - CAN signal from cruise control. Error Message : Malfunction. Error sporadic. Status :U0121 - CAN communication with parking brake control unit. Error Message : Malfunction. Error static. Status :U0151 - CAN communication with air conditioner control unit. Error Message : Malfunction. Error sporadic. Status :U0126 - CAN communication with central electronics. Error Message : Malfunction. Error static. Status :U0101 - CAN signal from cruise control. Error Message : Malfunction. Error sporadic.starter motor clicking, checked connections and earths,battery boost didn't work.
Nerius
11-18-2015 05:08 PM
cheezeburger
01-26-2015 10:40 AM
manycars
16
11-30-2013 04:05 PM
