Eurocharged ECU tune and pulley combo
#101
I'm also in Houston. Let me know if you decide to take the plunge. I won't do pulley/tune until my factory warranty ends in another 16K miles, but after that...
#102
If someone would off a hand held tuner like I had for my STi that would make this process much easier.
#104
I presume you had a Cobb AccessPort, I had the same for my Mazdaspeed3 (big turbo, custom e85 tune, blah blah blah). Being able to flash a stock tune if need be was a very big benefit, not to mention being able to do your own MAF Calibrations based on the current conditions.
#105
#106
Do it
I've had no issues since my EuroCharged ECU tune and pulley. I recommend that you have your ECU updated according to the recent recall notice before taking it to EuroCharged. Being in Houston will be very convenient if you ever have to have it re-installed. They only have a single cable they ship to those of us who are remote. I've been waiting to have my ECU recall tune so that it can be re-flashed with the Euro tune. The updated tune will not override any of the recall tune adjustments.
The added power is real. No issues whatsoever on it affecting any other part of the car other than the tires and brakes - I gotta learn to slow down.
#108
#109
I PM WaltB about the tune/pulley and he convince me to go for it. He loves his tune/pulley and has nothing but positive things to say. I really would like to get it as well after talking with him but I'm having a hard time finding someone willing to do the install. I called ten different places and when I told them that it was for a Jaguar, They drop me like I had the plague.. After much debate, I finally make up my mine and run right into a wall.
#110
#111
Flash Type: OBDII
MyGenius Compatible: Yes
Hmmm..
Anyone had them load their tune with your stock tune on this and successfully flashed back and forth without taking it back to them?
#113
#114
I had my Eurocharged tune and pulley done in January of this past year and I have had no problems at all. Just a lot of enjoyable time behind the wheel...
Eurocharged (01-15-2015)
#115
XF Supercharged 5.0
I bought an Eurocharged 1.5 pulley that I have not installed yet. I need to find a good puller tool to complete the install. I am also interested in a tune, and found a company called IAP Racing in Northern VA. The owner used to work for Eurocharged in VA. He said he now installs OE Tuning tunes. Is anyone familiar with this tune by chance? Also, any recommendations on the best way to do the pulley? I'd prefer avoiding cutting it off if I can.
#116
The only place I've heard of is Mina who has a loaner pulley puller that they customized. I went to a couple of shops and no one had anything that would work so they had to cut it.
I had a custom tune put in by a local tuner. You could contact them and they can help you I stall it remotely with a laptop. Or you could pull the ecu and send it to them to get programmed. If you search "Jailbreak" you can see all of my dyno runs and know how much power it will make (I have the Eurocharged pulley as well).
From what I understand, Eurocharged in VA was only open a short amount of time and they didn't seem very competent from some of the dyno charts they gave to customers. Many are satisfied with Eurocharged in Houston though, so not bashing Eurocharged, just want to make you aware of those involved in VA caused us to have a reason to question.
#117
#120
I called your shop (Eurocharged) today and asked what model pulley puller you use. The contact was going to research and call me but I did not hear back. Can you comment on what puller to use to install, or do you rent to customers? Also, what's the expected peak HP and torque with your 5.0L tune with your 1.5psi pulley?
