faulty parking sensor
I have a 2008 XF which I have only recently purchased. I am not sure if it is normal or a fault with the parking sensor. Today I pulled forward in to a parking space with a bush very close to the front of the car and the sensors started beeping to let me know I was a bit close. I stopped and turned off the engine and the beeping carried on. I then got out the car locked it when and did my shopping and when I returned 30 minutes later it was still beeping like mad.
As soon as I was clear of the bush the beeping stopped so it is clearly detecting things but not shutting off when the engine is turned off.
Any ideas would be appreciated wondering if this is a fault or simply a design issue with the computer
