Field Service Actions...??
k098 is a software update correcting some battery drain issues related to the ICE system remaining available after shutdown. The ICE remains accessible without switching the ignition back on for a period of time, between ten and thirty minutes. Apparently this was causing battery drain on some cars as the availability would not switch off.
Cant find anything on the other code. Any Jaguar dealer will know.
Ford Field Service Action is to ensure long-term reliability and trouble-free driving pleasure to our customers. Field Service Action is applicable only on select batches of Ford cars. Drivers may experience a different brake feeling when transitioning from regenerative breaking to hydraulic braking, and the brake warning light will illuminate. Brakes will continue to operate as pressure is applied to the pedal. It quite an informative and significant thread. One should go through the same and hence is a good knowledgeable aspect of the same.
