Front Brake Pads for XF SC
Replacing pads is easy. It's hard to say what pad prices should be but worst case you'd see $150-250 for pads from the dealer. Say it takes them 1-2 hours at about $150/hr.
$300-550 is my guess.
If you can get the correct pads on your own and you have the tools to do it you could swap them for fairly cheap. Searching online it appears most sites say the XF uses the same pads as the S-type. I'm not sure if that is correct and I'm sure the Supercharged and R versions have different pads as well, which isn't really showing up.
The XFR probably has those super fancy, super easy to change brake calipers that some of my other exotics had.
If so, it's literally takes more time to take the wheel off than to change the pads. An easy DIY, and pocket that $150-$300 for yourself.
And never buy anything from your local dealer parts counter because you'll pay full price. Lots of online dealers sell OEM at a big discount.
KarimPA
09-12-2015 08:15 AM
