Front Parking Sensor
Is it just me, or does one need to manually engage the parking sensor when wanting it for the front of the vehicle? I always notice the rear sensors operating when backing out of my garage or a parking spot, but on several occasions I find myself wondering why the alert isn't beeping when pulling into a garage or other tight space where front clearance is unknown.
Do I have to press the P>>> button every time I want the front sensors to activate? Or have I accidentally disabled them with all my button pushing?
The way it works on the Land Rover (and I suspect Jag also) is that engaging reverse fires up all parking sensors, front and rear. After a while they turn off automatically or you can turn them off with the "P" button (if a car sneaks up behind you having just reversed out of a garage spot for example). I assume you can manually engage them too if needed which seems to be what you observe. So do the front ones come on automatically when pulling head first into a slot without having just come out of reverse ? No, I think that's working as designed maybe not as desired ;-)
MonacoDK (03-25-2016)
Received 3,225 Likes
Onedark1 (03-28-2016)
Rickkk
03-21-2017 12:02 PM
Rocky15
03-08-2016 09:07 PM
