Front Seat Filters (C2C36093)
It a Ford seat filter. You can find them online for about $25 each.
https://www.google.com/search?q=Ford..._AUICCgB#spd=0
I just take mine off and blow air backwards to clean them out.
You can replace the filters for about 50p each:
Buy some thin polyester wadding from your local cloth factory outlet shop. It is used in quilting - you want the thin one that is about 5mm thick. You'll need to buy off the roll (typically 1.5m/5ft) so you'll end up with a lot left over. Take your old filter out and use it to template the new one making sure to cut the wadding 5mm larger than the disc. Use a sharp knife to cut off the old wadding from the plastic ring, then use normal cyanoacrylate glue to glue the ring to the new wadding, applying pressure until it has set. Then reinstall the filter.
https://www.jaguarforums.com/forum/x...cement-151676/
Probably none of them. I doubt it's on the service schedule, and even if it was, I really doubt they would bother for the included service contracts.
Just a matter of googling my friend. Your first google is on me, but I am sorry to say that you'll have to learn to do it yourself from now on:
mhessen6
10-12-2016 05:37 PM
1964Daimler
10-04-2016 10:02 AM
Blondie 1
09-30-2016 10:52 PM
