Fuel Filter Location - Jaguar XF 2010
Hey guys,
I was doing annual maintenance on my 2010 XF and I could not find the fuel filter to replace it. I saw some posts about a 2009 XF having the filter in the driver's side front wheel well, but I could not find it anywhere in there. I did see the fuel lines, so I know it probably wouldn't be in any of the other wheel wells. It makes sense that it would have been right there in the driver's side wheel well, but it isn't. Was the 2010 model updated?
Does anyone know where the fuel filter would be and how to access it to swap it out? It sounds like a lot of people have struggled in locating it... Thanks in advance!
I saw the DIY on the 2009 XF that said the same. I pulled back the liner on the driver's wheel well on my 2010 XF and the fuel filter was not there. Was the fuel filter location changed for later model years?
The following 3 users liked this post by BlackX300VDP:
I don't think it has an external, replaceable fuel filter. I believe just the filter sock at the pump does all the work. I looked on the parts catalog and a vin break shows up with a filter on cars prior to vin R47xxx and no filter after the vin which is likely what you have.
I ordered my parts using RockAuto, which did have fuel filters listed for my make/model/year. This is why I was so confused. Thanks for the help everyone.
My manual says to replace the fuel filter every 4 years, but when I called a dealer, they asked for my VIN (which is above R47xxx) and they said the fuel filter is in the tank/fuel pump, so he didn't have a part number. Does this mean I don't need to do anything unless I have a fuel pump problem?
The following 3 users liked this post by JLR_Tech:
Received 3,267 Likes
Yes, no need to do anything unless or until the fuel filter becomes clogged, and I've never heard of this happening on a 2010+ XF petrol.
