Fuel injector cleaner
Check first but I think Jaguar is now recommending BG 44K fuel additive.
Norseman02 (03-11-2015)
Modern fuels contain enough cleaner to keep the engine clean. The one real issue with DI is the fuel does not pass over the intake valves at all so fuel injector cleaner is a huge waste of money. You are literally burning your cash outlay directly in the combustion chamber. There is no way any fuel additive can make a difference. This has been a significant problem with some early to market DI systems. I note that some manufacturers are reverting to partial port injection on DI equipped engines and I wonder if this is just to keep some detergent flowing over the intake valves. These can carbon up due to valve overlap effects.
I was told to run a bottle of that BG 44K cleaner with every fill up. I know that's ridiculous but I may run some through every oil change or once a year. The car was already in for an injector clean that I narrowly escaped paying $300 for, and my car is under warranty. Apparently, it's a common issue on the Jags and running that BG cleaner is the best solution. I usually don't go for the magic bottle solution but everyone swears by this BG cleaner the more I research it. I picked some up off of Ebay for about $20. Not many stores seem to sell it.
For the DI motors you will probably want to run some through the intake to clean out the carbon deposits on the ports and valves. Most DI cars suffer from severe carbon build up on the valves where in the older motors fuel would keep it clean. I read through many posts on the Audi forum that noted the RS4 losing nearly 100hp after the carbon starts building up.
The cleaner will do squat to keep the valves clean as it does not touch them. The way to keep the valves as clean as possible is to keep the oil fresh and the EVAP and crankcase ventilation equipment as efficient as possible. The bad stuff that runs over the valves in a DI engine is coming from the crankcase, so keep it clean. That's about all you can do. Running something like 44K will stress the O2 sensors, they aren't made for those temps all the time.
I meant to say that, as already mentioned, some of the carbon comes from valve overlap when the intake and exhaust valve are open at the same time. Nothing you can do about it, but you can keep the crankcase systems clean and this will help. Dirty oil offgasses all kinds of stunky crud that can stick to valves
Received 2,263 Likes
If the dealer had not suggested this procedure, is there any difference in the way your engine runs now (as compared to 'new') that would make you think that something was wrong?
Ethanol is not Satan Incarnate as the snake oil sellers (like Startron) like to portray it. They're shilling their goods on the premise that 'bad things will happen' if you don't use it. I've been using E10 for 20+ years and never had ONE moment of trouble. This includes old carbureted cars and bikes as well as boats and garden implements.
The scamming is out of control.
If I were in your shoes, I'd wonder why all my cars seem to need injector cleaner on a regular basis when most other folks never use them.
As far as the BG44K goes, it's another fuel injector cleaner. You can't have it both ways, either they work or they don't. If none of the other brands work because they don't actually get to the injectors, then why would this one? If this one does work, why don't the others? My thoughts on this is, it doesn't matter if it's direct inject or not, the only important part of the injector on the outside is the end of the nozzle. The end of the nozzle has to be in the same space where the fuel comes out, because the fuel is coming out of it, so it would stand to reason that a fuel injector cleaner that works by breaking the carbon off the end of the nozzle by going through the fuel line and spraying out with the fuel will help clean and protect it.
Gus, my comment was in regards to it being mentioned that the only way to clean the intake valves on a direct injected car would be to pour it in through the intake.
I've used the BG cleaner in the tank and it works well..
