Fuel pump A control circuit/open (P0627)
Hey guys so recently when I was getting ready to warm my car before going home from work my car would not start. I got the car towed home scanned it and received a P0627 code for fuel pump A control circuit/open. I started off by checking fuses with my multimeter. The car also had 0 pounds for pressure so I knew it was the fuel pump at this point. I examined the fuel pump located behind the passenger back seat and noticed the fuel pump flange was burnt as well at the power connecter wire.
I’m not sure if I need to replace the wire connector or not but I’m sure I need to replace the fuel pump and fuel pump flange. Please help. Thanks guys! 2012 Jaguar XF/ without supercharger
Fixed
Hey guys just coming with an update. So far I replaced the pump and flange. The car is running great. Job was a 7/10 as hard of how hard it was because I didn’t drop the tank. I brought the pump off eBay for $230 with tax and the flange for $40.
https://www.autohausaz.com/pn/B2-C2D...SABEgLPvPD_BwE. https://www.ebay.com/itm/Electric-Fu...pid=6043547038. The link to both parts are listed here. Matching parts numbers!
My 2012 Jaguar is reading the same code! Do you know where the fuel pump relay is located? The manual isnt very helpful. Im thinking i have the same issue as u do. Quick question i took the back seat off and the carpet i found the rubber seal covering the fuel pump, do i just pull it off with the screwdriver? Thanks
The mechanic first changed the fuel pump module charged me $700 and obviously it didnt fix the issue. Then he comes back and says its the Fuel pump.
Ziffo
02-02-2021 03:11 PM
