Fuel rail bleeder valve
That engine is a DI engine and the fuel pressure are very high and dangerously so!
I don't know any way to bleed the pressure off other than loosening a fuel pipe connection to let it bleed down.
Just be careful as the pressures are many times higher than the older style port injection engines.
Is there a reason you want to bleed it down?
